petrol woes
Geocamper
Main scooter: Tv175 S2- Li 150 S2 Eibar
I have just returned from the petrol station and realised that I have put super unleaded 98 ron in instead of normal 95 Ron. It's a standard tv 175 rebuilt about 300 miles ago engine. Could this cause a problem?
DigDug
Only in your wallet.
Did you have to do that?
None whatsoever.
dave411
Main scooter: Li 125
Proably run better.
afandy
Petrol woes !! .....that's all I use on mine ....
Geocamper
Cheers Guys.
Sent from my iPad using Tapatalk
Chris in Margate
A lot of us will want to tell you that you should always be using highest octane you can find. In my opinion unless your timing has been deliberately retarded then you should steer clear of 95 octane. Others are going to disagree but higher octane petrol is less likely to pink (pre ignite) and cause damage.
My advice: always 97 or 98.
    Users browsing this forum: Google [Bot] and 13 guests
