How many turns out?
Posted: Sun Jan 24, 2016 6:43 pm
by S2CUF
So I've got an li150.. With a 175 kit. Stage 4 tuned.
Carb jetted 122 main and 50 pilot. How many turns out on the mix.?
Re: How many turns out?
Posted: Sun Jan 24, 2016 7:27 pm
by Doom Patrol
Is it a 20mm carb? Generally it's about one and a half.
Posted: Sun Jan 24, 2016 7:31 pm
by bristolmod
LI S3's had an 18mm carb as standard.
What carb is on there? If its 18mm then the main jet is way too big- you need around 105 for that set up.
If its 20mm then I would be looking at a 106/ 108 main
If its 22mm then possibly 118.
Depends of course on your atomiser; slide etc
Posted: Sun Jan 24, 2016 8:18 pm
by Chris in Margate
The correct number of turns will be when the engine responds on and off to throttle cleanly and pulls away from idle smoothly. So 1.5 turns is a good starting point but it could end up anywhere from 3/4 to 2.5 depending on the pilot jet and other jetting. Adjust when engine warmed up and after each small adjustment you need to rev it to clear and then reassess.
Posted: Sun Jan 24, 2016 8:23 pm
by S2CUF
Ok so it's just trial and error then.... It's a 22mm deltorro carb.
So what does this screw actuall do?? Out mean So? And in means?
Posted: Sun Jan 24, 2016 9:34 pm
by Muppet
S2CUF wrote:Ok so it's just trial and error then.... It's a 22mm deltorro carb.
in= weaker less fuel out= richer more fuel its a mixture screw not an air screw
