So I've got an li150.. With a 175 kit. Stage 4 tuned.
Carb jetted 122 main and 50 pilot. How many turns out on the mix.?
How many turns out?
- Doom Patrol
- registered user
- Main scooter: Jet 200
- Location: Second star on the right and straight on till morning
- Contact:
Is it a 20mm carb? Generally it's about one and a half.
bristolmod
- registered user
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
- Contact:
LI S3's had an 18mm carb as standard.
What carb is on there? If its 18mm then the main jet is way too big- you need around 105 for that set up.
If its 20mm then I would be looking at a 106/ 108 main
If its 22mm then possibly 118.
Depends of course on your atomiser; slide etc
Chris
Chris
Scootering since 1968.
Chris in Margate
- registered user
- Main scooter: Lambretta 1964 225 Special
- Contact:
The correct number of turns will be when the engine responds on and off to throttle cleanly and pulls away from idle smoothly. So 1.5 turns is a good starting point but it could end up anywhere from 3/4 to 2.5 depending on the pilot jet and other jetting. Adjust when engine warmed up and after each small adjustment you need to rev it to clear and then reassess.
in= weaker less fuel out= richer more fuel its a mixture screw not an air screwS2CUF wrote:Ok so it's just trial and error then.... It's a 22mm deltorro carb.
So what does this screw actuall do?? Out mean So? And in means?
C’est la vie
