T5 rattle
Posted: Fri Jan 01, 2016 7:33 pm
by drew2
Hi all,got a rattle from gearbox/clutch,when I pull the clutch in the rattle stops,
is it just a case of changing clutch plates or could it be something a bit more
sinister,thanks
Re: T5 rattle
Posted: Fri Jan 01, 2016 8:21 pm
by rosscla
That's sometimes a symptom of knackered bearings - check to see if the fly wheel moves in and out a bit when you work the clutch.
Re: T5 rattle
Posted: Fri Jan 01, 2016 8:46 pm
by mick1
The last clutch related noise I had was not a major catastrophe.
The "circlip" type wire for retaining the centre pressure plate was missing (never did find it ?).
This caused the pressure plate to "rattle" until the clutch was depressed.
