Adjusting gap chrome ring to headset
Posted: Sun Dec 27, 2015 9:25 am
by RBG
Fitted a new chrome ring to my S3 LI125 during a rebuild went to fit the headset and when the clamp is tightened up on to the forks
the headset tightens down and nips up onto the chrome ring when I've taken the headset off again got the Verniers out
and the new chrome ring is 1mm deeper than the original item.
Now before I file a little off the mating point on the clamp to lift the headset up is there any thing else I could do to get that 1mm back
or look at.
Re: Adjusting gap chrome ring to headset
Posted: Sun Dec 27, 2015 9:57 am
by hendy
I had the same thing on mine. Or at least I think you mean the same thing.
If there's any gap between the chrome ring and the top of the legshields you can bend it downwards with a mallet.
Posted: Sun Dec 27, 2015 10:08 am
by RBG
Don't have the leggies fitted yet, and shall not untill I've sorted the headset out.
Posted: Thu Dec 31, 2015 6:06 am
by RBG
Swapped out to an original ring and everything fits.
Posted: Thu Dec 31, 2015 8:12 am
by LI150
Deleted as when thought about my comment was b@11@x
Posted: Thu Dec 31, 2015 11:53 am
by bristolmod
I'd be inclined not to try to bend it with a mallet- risk of breakage!
