Hi folks,
im just building up a budget 200cc lammy engine, its a smallblock conversion, it came without a head so ive got a 150 head which is the correct stud pattern, but the wrong diameter combustion chamber, anyway ive had it in my lathe and opened it out to 66mm, my question is, should the machining of the head be exactly the same curviture as the piston crown, or should i leave a larger gap as i move away from the gasket, hope ive not confused everyone there.
holty
cylinder head reprofiling
Depends what squish velocity your aiming for.
I wasn't referring to the size of the squish.
holty
- registered user
- Main scooter: lambretta gp
- Contact:
did you mean that the angle/ profile determines the squish velocity, does that mean theres angle best suited to a lambretta? or more to do with the piston crown shape ?
its not a subject a know a lot about, other than it can make a big diffrent to how an engine runs.
holty
holty
fairspares
- registered user
- Main scooter: Lambretta GP RB252
- Contact:
without getting technical basically you have the squish band and combustion chamber , have a read at mbs info it may help
https://www.lambrettaspares.com/info/ty ... -x+54.html
predictably no mention of squish velocity therefairspares wrote:without getting technical basically you have the squish band and combustion chamber , have a read at mbs info it may help
this guy touches on it though
http://www.macdizzy.com/update39.html
this is very good for head design
http://bimotion.se/Head/BimotionAdvancedHead_Manual.pdf
have you downloaded the software?eden wrote:predictably no mention of squish velocity therefairspares wrote:without getting technical basically you have the squish band and combustion chamber , have a read at mbs info it may help
this is very good for head designit wont tell you what to aim for but it makes it much easier to get what ever you do decide on
C’est la vie
its one of the ones I have ye
- Information
Who is online
Users browsing this forum: Ahrefs [Bot], Google [Bot], Semrush [Bot] and 5 guests
