Gearing
Posted: Tue Dec 01, 2015 10:39 am
by Finny
Running rt195, mg clubman ,gp200 gearbox, 47 x 18 sprocket. All this is a final drive of 5.2. Thinking of getting nearer a final drive of 4.8. Changing drinker sprocket to a 20 with a 83 link chain appears the cheapest and easiest way to get near 4.8 (actually gives a final driv of 4.7).
Kit is described as able to cope with this final drive.
Are there any problems I might encounter. Would the sacrifice of low end make riding s pig (only ride one up and a mix of dual carriage ways, traffic, rural bends with slow elderly couples driving to somewhere to have a flask of tea!).
Thanks
Re: Gearing
Posted: Tue Dec 01, 2015 10:50 am
by HxPaul
Re: Gearing
Posted: Tue Dec 01, 2015 12:29 pm
by Finny
Thanks. Want to try and avoid changing gearbox. Any run a similar gearing set up 47,20 and 83 chain?
Re: Gearing
Posted: Tue Dec 01, 2015 2:33 pm
by YAMLAM
why not go 19/46, gives 4.84 18 x 47 chain should fit.
Re: Gearing
Posted: Wed Dec 02, 2015 1:22 pm
by Muppet
YAMLAM wrote:why not go 19/46, gives 4.84 18 x 47 chain should fit.
+1 this mite be betta
Re: Gearing
Posted: Wed Dec 02, 2015 9:18 pm
by Grumpy225
That's what I run on mine and get a true GPS verified 70mph out of it.
24 dellorto
BGM V2 box exhaust
Re: Gearing
Posted: Thu Dec 03, 2015 5:34 pm
by Finny
Thanks for replies. Taken advice on board and goin with 46x19. Next issue is exhaust...............
Re: Gearing
Posted: Thu Dec 03, 2015 6:20 pm
by ducksta
19x46 with a 400/10
Re: Gearing
Posted: Thu Dec 03, 2015 11:09 pm
by YAMLAM
Running rt195, mg clubman thought you already had exhaust ??
Re: Gearing
Posted: Fri Dec 04, 2015 3:31 am
by corrado
If you change the exhaust then all the above info goes out of the window.
