gearbox
ducksta
Got a px 125 casing need a new gearbox, been offerd a complete 200 kit 23 tooth clutch etc will it work ok ie will it pull with a polini kit
How torquey is it? My 187 pulls 200 gearing (short 4th), with ease, with a JL pipe on it. It's not a rev monster though.
ducksta
Polini 180kit ported and long stroked 24/24 carb revolver exhaust lightend flywheel
Toot-oasc
ducksta wrote:Polini 180kit ported and long stroked 24/24 carb revolver exhaust lightend flywheel
A PX 125/150/T5 gearbox will do the job really well, particularly with the shortened 4th gear. You might struggle to keep in the rev range to fully use a P200 gearbox in a 180 motor without messing about with the primary drive.
paul d
Main scooter: T5 172 Tv 240
I'm guessing the p200 gearbox you've been offered has a 65 primary due to the 23tooth clutch. With a 21tooth cog in the clutch and a 125 4th gear, the ratio would be very close to a 125 gearbox. I've never ran a polini 180 but I'm sure it would pull the above set up easily.
ducksta
cheers guys got some guide lines to work with will go 21 tooth and 125 4th
