New nikasil re-line - have a sent the right piston?
alanscottj
I have just sent my TS1 barrel off to Langcourts for a re-line following my seize and have included in the parcel a new TS1 piston. The piston that I have sent is a 'B' piston, will this be ok, I'm assuming they will re-line the barrel using the piston to set the clearance. The only reason I ask is because it is a relatively new kit and the original knackered piston was a 'A' piston. Hope that makes sense ;)
TS1-200
That`l be fine they will reline and machine cylinder to suit your piston.
Keep on keepin on
alanscottj
TS1-200 wrote:That`l be fine they will reline and machine cylinder to suit your piston.
I thought so, just thought I'd check, cheers bud :D
mark1
Main scooter: gp
How much does the re-line cost mate. I've got a ts barrel that needs to be relined.
alanscottj
mark1 wrote:How much does the re-line cost mate. I've got a ts barrel that needs to be relined.
£105 + vat + return post = £138 I think it was, give or take a quid :D
That's if it is a simple re-line with no welding work required
mark1
Main scooter: gp
Cheers mate.
