gearbox
ducksta
Got a px 125 casing need a new gearbox, been offerd a complete 200 kit 23 tooth clutch etc will it work ok ie will it pull with a polini kit
How torquey is it? My 187 pulls 200 gearing (short 4th), with ease, with a JL pipe on it. It's not a rev monster though.
ducksta
Polini 180kit ported and long stroked 24/24 carb revolver exhaust lightend flywheel
Toot-oasc
ducksta wrote:Polini 180kit ported and long stroked 24/24 carb revolver exhaust lightend flywheel
A PX 125/150/T5 gearbox will do the job really well, particularly with the shortened 4th gear. You might struggle to keep in the rev range to fully use a P200 gearbox in a 180 motor without messing about with the primary drive.
paul d
Main scooter: T5 172 Tv 240
I'm guessing the p200 gearbox you've been offered has a 65 primary due to the 23tooth clutch. With a 21tooth cog in the clutch and a 125 4th gear, the ratio would be very close to a 125 gearbox. I've never ran a polini 180 but I'm sure it would pull the above set up easily.
ducksta
cheers guys got some guide lines to work with will go 21 tooth and 125 4th
    Users browsing this forum: Google [Bot] and 63 guests
