6v BGM Stator
Arch_Stanton
One for the electrical boffins.
I want to loose the points on my series one, but would like to keep the 6volt lighting system.
Can I just swap the 12v lighting coils for 6v and wire them up the same on the stator?
Will the original 6v rectifier designed for a 4 pole stator cope with the output?
Firstly that seems like a retrograde conversion
secondly changing everything over just seems like a long way around a problem
if i4 was me id get a 12v to 6v step down converter or use a 12v dc stator and a 12/24v to 6v wassell type unit
if your worried about looks then get an old rectifier/ regularor hollow it out and fit what ever you want inside
ouh and good luck :)
