I have the shim fitted. Would having the clutch in pull the tree up or do I need another shim?
Is it an aftermarket Indian Li 150 gearbox? If so I had one and it knackered the christmas tree bearing track.Running it without the shim was the only solution.Snails wrote:I dont think my xmas tree should be rubbing on the casing like this should it
MB bearing no sealhendy wrote:My money says it's a seal.
Better tek it oot.
If you have packed that much grease in the bearing to look like a seal,rosscla wrote:I think that's just the grease you're seeing, no seal?
