Not so merry christmas
Snails
I dont think my xmas tree should be rubbing on the casing like this should it :(
I have the shim fitted. Would having the clutch in pull the tree up or do I need another shim?
Is the shim in under the outer bearing race in the casing? Don't see it in the picture?
Might be the roller race is hiding it -
But the track looks a long way in.
Daggs
Your picture of the layshaft main bearing shows the plastic seals in. Which I don't recommend...........
I think that's just the grease you're seeing, no seal?
Daggs
Gawd! That's a fair bit of grease.................. :lol:
hendy
My money says it's a seal.
Better tek it oot.
hendy
Better tek it oot.
HxPaul
Snails wrote:I dont think my xmas tree should be rubbing on the casing like this should it :(
Is it an aftermarket Indian Li 150 gearbox? If so I had one and it knackered the christmas tree bearing track.Running it without the shim was the only solution.
hendy wrote:My money says it's a seal.
Better tek it oot.
MB bearing no seal
lambro
rosscla wrote:I think that's just the grease you're seeing, no seal?
If you have packed that much grease in the bearing to look like a seal,
Will the clutch plates like that?
Just curious.
    Users browsing this forum: Majestic-12 [Bot] and 5 guests
