Atomic clutch mods
Knowledge
I hear good things about the Atomic clutch components. Scoot RS do their Atomic clutch centres in three versions, GP, Li and early Li with a spindle.
My Li 150 'box has the Xmas tree drilled for the early Li spindle, but the side casing is GP. Previously, I have ground the Li nipple of the Innocenti spindle clutch centre to suit this combination of components, but can I do the same with the Scoot RS component without compromising the contraction of the pressure plate?
Martin
If I remember I'll bring them to Bridlington and you can look at them up close and make your own conclusion. Assuming that you'll be there?
Knowledge
Yes, I'll be there, and will probably buy one if you have got one. :D
Martin
