Rich jetting for TS1-225 for running in?
Posted: Thu Sep 17, 2015 8:24 pm
by alanscottj
Getting my TS1 barrel back from Langcourts tomorrow, I really don't want to have a repeat seize so I'm looking for some jetting advice for a rich setting to run in. I will also be having my timing set/checked by strobe and doing a leak test to cover all bases.
My set up:
TS1-225
Dellorto 30mm
JL3
Thanks
Scott
Re: Rich jetting for TS1-225 for running in?
Posted: Thu Sep 17, 2015 11:15 pm
by Grumpy225
Why break it in rich? It's a plated cylinder.
Posted: Thu Sep 17, 2015 11:16 pm
by alanscottj
Grumpy225 wrote:Why break it in rich? It's a plated cylinder.
It's been relined with Nikasil
Posted: Thu Sep 17, 2015 11:52 pm
by Grumpy225
alanscottj wrote:Grumpy225 wrote:Why break it in rich? It's a plated cylinder.
Yes, Nikasil=plated.
If it's jetted and timed correctly, then it will run correctly. Too rich or too lean will cause it to run hot and have problems.
Posted: Fri Sep 18, 2015 8:07 am
by shocky
What caused it to sieze in the first place as that needs addressing even if its "unknown" hope you get it sorted
