Rich jetting for TS1-225 for running in?
alanscottj
Getting my TS1 barrel back from Langcourts tomorrow, I really don't want to have a repeat seize so I'm looking for some jetting advice for a rich setting to run in. I will also be having my timing set/checked by strobe and doing a leak test to cover all bases.
My set up:
TS1-225
Dellorto 30mm
JL3
Thanks
Scott
Grumpy225
Why break it in rich? It's a plated cylinder.
alanscottj
Grumpy225 wrote:Why break it in rich? It's a plated cylinder.
It's been relined with Nikasil
Grumpy225
Yes, Nikasil=plated.
If it's jetted and timed correctly, then it will run correctly. Too rich or too lean will cause it to run hot and have problems.
What caused it to sieze in the first place as that needs addressing even if its "unknown" hope you get it sorted
