phbh needle help
Posted: Mon Sep 14, 2015 7:58 pm
Hi All,
Still chasing the elusive perfect set up
current set up;
Pilot 55 3 turns out
40 slide
Av268
X7 needle 2nd clip
Main jet 134
choke 70
My panel filter
AF 9-5-1 Head
scoot RS with better end can
sx150 gear box 47 x 18 sprockets.
Seem to be very close now, starts first kick warm or cold idle to 1/4 perfect 1/2 to 3/4 possibly too lean, full throttle perfect.
after lots of choke tests all through the rev range I think 1/2 to 3/4 is on the lean side.
so folks I'm thinking a change of taper might help? but unsure which path to follow?
to richen 1/2 to 3/4 am I correct in thinking lift the needle to 2.5 or 3 clip position or would it be better to try x13 on the 1st or 2nd clip position?
any advice on this would be greatly appreciated!
current set up;
40 slide
Av268
X7 needle 2nd clip
Main jet 134
choke 70
My panel filter
AF 9-5-1 Head
