phbh needle help
Markymark
Main scooter: Lambretta Gp150
Hi All,
Still chasing the elusive perfect set up :lol:
current set up;
Pilot 55 3 turns out
40 slide
Av268
X7 needle 2nd clip
Main jet 134
choke 70
My panel filter
AF 9-5-1 Head
scoot RS with better end can
sx150 gear box 47 x 18 sprockets.
Seem to be very close now, starts first kick warm or cold idle to 1/4 perfect 1/2 to 3/4 possibly too lean, full throttle perfect.
after lots of choke tests all through the rev range I think 1/2 to 3/4 is on the lean side.
so folks I'm thinking a change of taper might help? but unsure which path to follow?
to richen 1/2 to 3/4 am I correct in thinking lift the needle to 2.5 or 3 clip position or would it be better to try x13 on the 1st or 2nd clip position?
any advice on this would be greatly appreciated! :D
Muppet
Markymark wrote:Hi All,
current set up;
40 slide
Av268
X7 needle 2nd clip
Main jet 134
choke 70
My panel filter
AF 9-5-1 Head
y sure its lean then rich?
C’est la vie
Markymark
Hi Muppet,
Yes when choke is on in 3rd gear I get splutter up to 1/2 throttle then splutter 3/4 full,
1/2 to 3/4 makes no noticeable difference with the choke on so am assuming this is a needle issue?
this is on a Cast iron 225 factory tune with porting cleaned up cases matched and runs very well with virtually no spit back.
Muppet
float valve size?
C’est la vie
Markymark
    Users browsing this forum: No registered users and 64 guests
