Hi All
I have been in the man cave today trying to install a MBD race tour 47tooth crownwheel and Spider. The problema is when I torque the bolt up both parts wont turn independently. I have tried the same crownwheel and spider on two diferent engines with the same result, I then try a SIL GP crownwheel and spider on the same two engines and it works perfectly. This is really worrying me as it took me a long time to stash the cash for said crownwheel and spider and I thought MBD parts were good quality plug and play parts.
MBD Race Tour Clutch
- registered user
- Main scooter: Lambretta
- Contact:
Put the spider in the crownwheel, lay it face down on the bench and place a flat edge across the back. The centre of the spider should be higher than the crownwheel but only by about 0.1 of a mm.
If not it will not work properly, as you tighten the nut the spider will pull down into the crownwheel and jam them together.
- registered user
- Contact:
Sounds like not enough clearance, phone MB
Andoni
- registered user
- Main scooter: SX-200 Eibar
- Contact:
I agree with rosscla
The shim in- between the chritmass three and the spider must be flat, in good condition too... only needs to touch the spider, never the crownwheel once you tight the clutch locking nut
- wack 63
- registered user
- Main scooter: '71 GP TS1
- Contact:
MB sell shims to fit on the spider if it is too long so they may do one to fit on top of the clutch shim. If not , a Cyclone one could be used or why not flat the crownwheel centre on a sheet of emery?
hendy
- registered user
- Main scooter: lambretta li 125
- Contact:
I used a sharpening stone and a drop of oil. Gently lapped in for 2 minutes and it was spot on.wack 63 wrote:MB sell shims to fit on the spider if it is too long so they may do one to fit on top of the clutch shim. If not , a Cyclone one could be used or why not flat the crownwheel centre on a sheet of emery?
