Power jet 34 vhsh
Jonn
Cant remember if it was on here but someone,was trying a TS1 with 34 mm vhsh,with a power jet fitted.Was wondering how things turned out as I want to try this.
I've fitted one to a 30 VHSH but I'm currently not able to give much advice at the moment as I'm chasing an air leak. What I did find is that fitting it as close to 12 o'clock and shortening the brass tube helped to ensure that it didn't come in too early.
Others have fitted them an should be able to give you more feedback.
Best of luck.
Adam
