crank woes
sydduckett
Taken a chunk out of crank taper on opposite site to wood ruff slot. Think the wood ruff key shearing caused this.
Question I have is...is the crank okay as is or does it need repairing?
here is a pic: Image
https://dl.dropboxusercontent.com/u/119 ... 0%2014.jpg
Ta, Sef
Grumpy225
It's the taper that holds the flywheel to the crank. The woodruf key is only for alignment.
You can try to use grinding paste to surface the two tapers but at the end of the day the flywheel is making less than 100% contact to the crank and WILL spin off again.
Does no one retorque the flywheel nut after the first run? It seems like there have been a lot of key shearing problems on the forum lately.
