Quattrini help!
kayle
- Main scooter: Quattrini 172 street racer
I have just bought a new quattrini m1x kit for my px125. I'm using standard flywheel and crankshaft although it's been cut and polished, I need info on this kit, timing, premix ratio running in instructions ect any help is appreciated as I'm completely stuck
I'm not saying you can't get the info here, but another option for you. Vespasmallframeforum give it a try
Good luck.
Good luck.
Sean (Scooterotica) has built a few of these kits.........might be worth a call
cartmel808
- Main scooter: 1975 Vespa Rally 200 Femsa
Mines the M1XL with direct intake & reed on barrel & I run 3% mix with good quality synthetic - static timing is recommended @ 16 deg (or 19 deg for vespatronic) - running in period on mine was a tank of fuel
....then straight on the dyno to get everything dialed in properly.
Sean Bradey @ Scooterotica built mine for me, so (as Morgan said) would be worth giving him a call...
