Quattrini help!
kayle
Main scooter: Quattrini 172 street racer
I have just bought a new quattrini m1x kit for my px125. I'm using standard flywheel and crankshaft although it's been cut and polished, I need info on this kit, timing, premix ratio running in instructions ect any help is appreciated as I'm completely stuck
cgt75b
Main scooter: lambretta
I'm not saying you can't get the info here, but another option for you. Vespasmallframeforum give it a try
Good luck.
Morgan
Main scooter: T5 Vespa Mk1
Sean (Scooterotica) has built a few of these kits.........might be worth a call
cartmel808
Mines the M1XL with direct intake & reed on barrel & I run 3% mix with good quality synthetic - static timing is recommended @ 16 deg (or 19 deg for vespatronic) - running in period on mine was a tank of fuel :D ....then straight on the dyno to get everything dialed in properly.
Sean Bradey @ Scooterotica built mine for me, so (as Morgan said) would be worth giving him a call...
kayle
Thanks everyone I will give him a call after the bank holiday, much appreciated!
