Quattrini help!
Posted: Sun Aug 23, 2015 9:06 pm
by kayle
I have just bought a new quattrini m1x kit for my px125. I'm using standard flywheel and crankshaft although it's been cut and polished, I need info on this kit, timing, premix ratio running in instructions ect any help is appreciated as I'm completely stuck
Re: Quattrini help!
Posted: Sun Aug 23, 2015 9:23 pm
by cgt75b
I'm not saying you can't get the info here, but another option for you. Vespasmallframeforum give it a try
Good luck.
Re: Quattrini help!
Posted: Sun Aug 23, 2015 9:50 pm
by Morgan
Sean (Scooterotica) has built a few of these kits.........might be worth a call
Re: Quattrini help!
Posted: Mon Aug 24, 2015 9:31 am
by cartmel808
Mines the M1XL with direct intake & reed on barrel & I run 3% mix with good quality synthetic - static timing is recommended @ 16 deg (or 19 deg for vespatronic) - running in period on mine was a tank of fuel
....then straight on the dyno to get everything dialed in properly.
Sean Bradey @ Scooterotica built mine for me, so (as Morgan said) would be worth giving him a call...
Re: Quattrini help!
Posted: Mon Aug 31, 2015 10:22 am
by kayle
Thanks everyone I will give him a call after the bank holiday, much appreciated!
