hub wheel studs thread size
philcasino1973
Main scooter: lambretta gp200
does anyone know the thread size/pitch for the left hand thread on front/ rear hubs
changing to sip tubeless rims and forgot thet need the longer studs in.......freshly painted hubs and having a nightmare removing originals
2 out ok and two solid .am having to drill out and need to buy taps to suit
taaaaaaaa
phil
gaz_powell
10x1 LH is the common one but there are some 11x1 LH examples out there (not sure which manufacturers they are )
philcasino1973
ta gaz its the original 63 li125 hub and is a 10mm
so its a std pitch not the fine then?
ta
phil
Std metric coarse pitch for M10 should be 1.5mm. the hub studs are left hand M10 x 1.
You can get the tap from eBay, Chinese ones are cheap enough and adequate for the job of cleaning up threads. They take abou a week to arrive.
