clutch problem
Posted: Fri Aug 14, 2015 4:50 pm
by Matt black
Got a t5 classic set off few days ago first andsecond gear ok put into third and not engaging just revving . Occaisoinally it will engage sometimes no gears at all ! Checked selector that is changing to every gear fine going away tomorrow for a week but any ideas where to start when I return much appreciated lads. Engine was rebuilt 18 months ago all new seals bearings and genuine cruxiform put in. Thanks in advance.
Re: clutch problem
Posted: Fri Aug 14, 2015 6:16 pm
by Norrie Bodge
Push rod that cruciform is fixed too loose?
Or gear selector arm pin loose maybe?
Re: clutch problem
Posted: Sat Aug 15, 2015 5:38 pm
by Matt black
Cheers for that checked pin is ok will look at the other when I back home.
Re: clutch problem
Posted: Sun Aug 23, 2015 6:27 pm
by Matt black
Selector arm pin was indeed out completely I assumed cos it was changing gears it was ok thanks for the advice norrie cheers.
