clutch problem
Matt black
- Dealer
- Main scooter: vespa t5
- Contact:
Got a t5 classic set off few days ago first andsecond gear ok put into third and not engaging just revving . Occaisoinally it will engage sometimes no gears at all ! Checked selector that is changing to every gear fine going away tomorrow for a week but any ideas where to start when I return much appreciated lads. Engine was rebuilt 18 months ago all new seals bearings and genuine cruxiform put in. Thanks in advance.
Norrie Bodge
- registered user
- Main scooter: GP-1971-Ts230/S2-1960-Ts230
- Contact:
Push rod that cruciform is fixed too loose?
Or gear selector arm pin loose maybe?
Matt black
- Dealer
- Contact:
Cheers for that checked pin is ok will look at the other when I back home.
Matt black
- Dealer
- Contact:
Selector arm pin was indeed out completely I assumed cos it was changing gears it was ok thanks for the advice norrie cheers.
