engine won't rev and smokes
fajes
hey,
it's been a while since I've been here!
so it was also a while since I've ridden my S2. when I tried to get her going again she'd go for 100mtrs and die, as in rev drops and dies. checked the carb (22 jetex), cleaned the jets, replaced the fueltab with a new fast flow tab,... tried again, yes she starts, idles, runs! but yet again she ran 100mtrs and the same thing happens...
there's also a lot more smoke than normal.
any suggestions?
since it's been a while: the engine is a standard 1960 Li150 with a GP150 kit, elec ignition and Jetex carb. I used to commute on it, but the last few years it's only been used for the occasional little ride around town.
wine for my men, we ride at dawn!
I've had a very similar issue which was down to a faulty plug
fajes
that would be a simple solution, I'll try it after I finish work.
mick1
Main scooter: Li Avanti 225
change the fuel......
fajes
the fuel was changed when I replaced the fuel tab.
Timbo
Stater breaking down....
bristolmod
semi blocked jet or passageway in carb
Scootering since 1968.
fajes
hmmm, I cleaned out the carb and jets.
I do have quite a lot of spit back in the airfilter rubber.
DigDug
Breather hole in petrol cap blocked?
Did you have to do that?
HxPaul
You say it smokes a lot,is it white smoke,if so it could be your main drive seal thats failed causing your spark plug to become fouled.
    Users browsing this forum: Semrush [Bot] and 6 guests
