Damn & Blast !!!! again
Posted: Thu Jul 23, 2015 11:54 am
by mickymidas
Happened again !!!
Flywheel side bearing race working its way off crank & pushing through seal , leaving bearing on the p#$$. Any ideas of the cause & how to rectify the problem ?
HB stage 4 P200 kit , HB fettled crank , B8es plug , 4% oil .
Re: Damn & Blast !!!! again
Posted: Thu Jul 23, 2015 1:19 pm
by eden
New crank with a less worn race seating.
Posted: Thu Jul 23, 2015 1:57 pm
by mickymidas
Cheers pal , think I had already made my mind up a new crank was needed , but needed a nudge in that direction :)
Posted: Thu Jul 23, 2015 5:36 pm
by wack 63
Depending on how worn the crank is where the bearing sits, you may get away with some bearing retainer.
Posted: Sat Jul 25, 2015 1:26 am
by Ginch
And if the crank is buggered anyway, you could try a fairly liquid high temp epoxy to glue it into position.
Posted: Sat Jul 25, 2015 10:25 am
by fastfrog
Got the very same issue on my tameni T5 crank. Race was easy to fit on the crank shaft. Usually it needs a certain amount of strength to shove it down. Crank and bearing were brand new and I tried another bearing just to see and it the very same prob. Shaft was a bit to narrow. I glued the whole thing with a big amount of Loctite 648 and it never happened again....
Posted: Sat Jul 25, 2015 3:52 pm
by oldbiker
there are bearing grades of loctite, but i`d be tempted to go for a new crank and bearing
