MK1 T5
lambro
Should anyone be silly enough to put down a gearcable stopper (black bullety bit goes in the metal base) and not be able to find it,
And then be so impatient to build, a 2 day order is out of the question.
Turns out a lambretta front brake cable top hat is just made for the job :D
So I hear anyway :oops:
buttontobutton
Happened to me on my T5 years and years ago. If I remember rightly, I used a 2 pence piece with a hole drilled in it large enough for the inner to pass through, then fixed the tuppence with a self-tapper to the inside of the headset base. Worked a treat and was still there when I sold the bike years later!
