Vespa px200E boggie bottom end
boxofbits
Just rebuilt an engine px 200 e iris new seals bearings–new top end (all standard) as the engine had done alot of miles and needed a bit of tlc - Its really boggy at the bottom end—fine on tick over and once past ¼ throttle its off –but you have to rev it at the traffic lights else it stalls. I’ve tried a new float needle and a new plug and there no difference . I’ve checked no petrol in the gearbox oil- Adjusting the mixture screw does nothing either- Jets are 118 BE3 – 160 and pilot 55/160 – any ideas :oops: It did have 16 BE3 – 160 and pilot 50/160 in it when i got it- but it wouldn't tick over
LI225Canada
Main scooter: Serveta LI150 Special
Did you happen to replace the fuel line?
I had simulare symptoms on a friends P200 after I replaced his leaking fuel line with one 6" longer than the original.
Cut it back to the same length as the original and all was good.
boxofbits
I will have a look, how long should it be?
fastfrog
what sort of slide do you have on it? A 04?
I guess you have an autolube PX200E so you don't need a 118 main jet but a 116.
Size matters!
boxofbits
Its a non auto lube it's its spanish 87 px 200 e iris I can't find a manual which says the standard jetting these model have
boxofbits
It's a 04 slide
fastfrog
and main jet is 118. My mistake.....
your mixture screw? how much did you wind it out?
Size matters!
boxofbits
2 turns out is the mixture screw , also the idel is fulling wound in to make it tick over
LI225Canada
boxofbits wrote:I will have a look, how long should it be?
63cm.
mick1
Main scooter: Li Avanti 225
Could be choke not fully shutting off......worth checking.
    Users browsing this forum: Google [Bot] and 19 guests
