Vespa px200E boggie bottom end
Just rebuilt an engine px 200 e iris new seals bearings–new top end (all standard) as the engine had done alot of miles and needed a bit of tlc - Its really boggy at the bottom end—fine on tick over and once past ¼ throttle its off –but you have to rev it at the traffic lights else it stalls. I’ve tried a new float needle and a new plug and there no difference . I’ve checked no petrol in the gearbox oil- Adjusting the mixture screw does nothing either- Jets are 118 BE3 – 160 and pilot 55/160 – any ideas
It did have 16 BE3 – 160 and pilot 50/160 in it when i got it- but it wouldn't tick over
LI225Canada
- registered user
- Main scooter: Serveta LI150 Special
Did you happen to replace the fuel line?
I had simulare symptoms on a friends P200 after I replaced his leaking fuel line with one 6" longer than the original.
Cut it back to the same length as the original and all was good.
I will have a look, how long should it be?
Its a non auto lube it's its spanish 87 px 200 e iris I can't find a manual which says the standard jetting these model have
It's a 04 slide
2 turns out is the mixture screw , also the idel is fulling wound in to make it tick over
LI225Canada
- registered user
63cm.boxofbits wrote:I will have a look, how long should it be?
