Lower frame cone
chippy
Just stripped a Spanish Li frame and the lower frame cone is the tall type. Can I replace it with the shorter type as I have one in shed or is like that for a reason :D
DigDug
Yes you can as long as it's a good fit.
Did you have to do that?
chippy
DigDug wrote:Yes you can as long as it's a good fit.
Thanks for that, it is tight and will need warming to get it in. I only removed it as My forks were really tight on the one I removed but are fine on new one.
