26mm Phbl on 175 cc
alanscottj
Can anyone give me a ball park jetting for a 26 mm Delly Phbl with a 175 top end? Thanks in advance :D
Just had a look in there:
270k atomiser
D36 needle
98 main
60 choke
50 pilot
That's what it came with when I bought it apart from 98 main which I have swapped, it was a 118.
PHBL 26 is a rare carb for a Lambretta. Generally people would use a PHBL25 or PHBH26, so I think you'll struggle to find anyone else using one.
alanscottj
corrado wrote:PHBL 26 is a rare carb for a Lambretta. Generally people would use a PHBL25 or PHBH26, so I think you'll struggle to find anyone else using one.
Yeah, bought it thinking it was a PHBH, my fault for not checking :roll:
dave wheeler
im using a 24mm phbl on a tv175 with an ancilloti clubman, slide 40, choke 60, pilot 50, D22 third notch, 100 main, i know its not the same size but go up 10p/c should get you a ballpark setting, depends on the pipe youre using of course
