Springs (7) on rear of rear sprocket .
Rotor
Main scooter: 1960 S2 Italian
Now I not done a lot of these, but don't think this is quite normal, is this a shock absorbing up grade, sure this isn't a standard thing, but quite happy to go to the back of class if so ! Has the basket and five springs on the front though, just stripping as slipping like crazy at 55 and dragging on idle, thoughts ? :shock:
bristolmod
do you mean the internal springs on the rear sprocket?
If so, these were phased out during the S3 run due, I think, to costs and the fact that they broke up.
Replaced with a solid rear sprocket which is OK but can give a "thump" when putting into gear (the earlier springs absorbed any snatching etc)
The earlier ones do not last long in a tuned motor!
Chris
Scootering since 1968.
Rotor
Agh this makes perfect sense thanks for the quick reply, think I may take it out and build up a new clutch , P.
    Users browsing this forum: Google [Bot], Google Adsense [Bot] and 1 guest
