Lambretta Spare Wheel Oil Tank
lambrettaadditions
Hi guys just wondering if anyone would be interested in these Lambretta Oil Tanks
Fits straight to spare wheel . Easy to fill and has a fitted drain tap with
removable key which fits onto your key ring. Comes in a satin brushed finish .
The tank holds 1.5 liters and handy for longer distances
Will fit wheel size of 240mm internal wheel with 225 hole centers.
£70 and £6 shipping
dapper
I've just made a similar type but bigger for spare fuel instead of having to carry a green plastic can on me rack. If you could make that bigger and it could hold 5 litres of petrol, I'd be interested. ;)
Yanker
Does the cap incorporate a breather that is permenantly open.
Would one suitable for horizontally mounted spares be possible? IE alternative version of the tap, or, at the end of the day, is the key mechanism really neccesary?
What about one with a central tube for those vertical rear carrier spares? I reckon there are more of those than inside leg spare carriers with Symetrical 240mm internal wheel with 225 hole centers
Fundamentaly IMHO the volume is too low and not worth the coin: You could do with at least 4Lt, or stuck a 1Lt in your pocket if there was really no otheralternative....
