GP fork buffers
dazz-uk
Which way round do they fit, smaller ones under the link on the bottom? larger ones above? thanks for any info. its my first time at doing my forks, thanks
Sticky's vol 2 page 218, clear as mud. I've always fitted thin at top, 1st to go in and thick at bottom. I hate fitting the thick ones and last couple I've done I've drilled the forks and fitted the bolt in type after removing the inner clips on the forks.
