Page 1 of 2
Lambretta cylinder head damage
Posted: Wed May 20, 2015 7:08 pm
by DickieD
Rebuilding my brother-in-laws Mugello 186 motor ant the cylinder head has a lot of pitting etc from when the small end bearing fell apart. Can anyone tell me if this can be clean up and used or is it better to get a new cylinder head?
20150520_165756 by
Paul Davies, on Flickr
Re: Lambretta cylinder head damage
Posted: Wed May 20, 2015 7:21 pm
by bristolmod
I'd say clean up and use.
Posted: Wed May 20, 2015 7:39 pm
by mick1
Maybe give it a skim and use a thicker head gasket
Posted: Wed May 20, 2015 8:56 pm
by DickieD
Thanks for replies might just clean it up and see how it goes.
Paul
Posted: Wed May 20, 2015 9:03 pm
by mick1
i'd leak test it before use. suck in a bit of air and you may hole the piston
Posted: Thu May 21, 2015 9:54 am
by onthelam
If you have a dremel with small sanding cylinders
don't use the tool but just sand the squish band to knock of the sharp bits . Then finish off with some finer 200 grit. The sharp edges will promote detonation if the engine is prone to it. It doesn't have to be like a baby's bum but the smoother the better. This method involves time, effort and dust.
Posted: Tue May 26, 2015 8:26 pm
by DickieD
Cheers for advice so far. I have managed to get out the garage today and clean up the head but still not 100% happy with it. Some of the damage is deep. Has anyone ran one like this without any problems. If it was for me I would run it as is but it's not my money so need to make sure.
20150526_161805 by
Posted: Tue May 26, 2015 8:33 pm
by Muppet
skim reprofile
Posted: Tue May 26, 2015 8:39 pm
by DickieD
Cheers Muppet,
That is one option, he is on a tight budget so don't really want to buy a new head.
Posted: Wed May 27, 2015 2:31 am
by Grumpy225
You should really have the damaged part cut off the head and then run a thicker head gasket to make up the height difference. I'm sure after all that sanding work the sealing surface if far from flat and will always cause problems.
