Poor running / starting
watto66
Hi all
im having a bit of teething issue with a li 125 / 3 ( fitted with SR 185 kit, cleaned ports , checked tolerances etc from engineering trader ) it has new BGM 120w stator , new cdi etc engine rebuilt . Keeps flooding it will start then boggs up , clean plug i keep kicking then starts again. The rubber hose is full of fuel after it cuts out. The bike was running and starting lovely last week . The only thing that has changed is a replaced the rubber hose with a thicker casa type. Now the carb is a Jetex ( here we go ) 22mm jetted for GP 200 first time ive ever had one of these bought from a reputable dealer on the south coast who has sold them "reworked" any thoughts
many thanks
bristolmod
it does sound like the carb I'm afraid.
I've got 5 out in the shed- problem is that they seem to "go off" without any warning. If you want to borrow one please be my guest.
Chris
Scootering since 1968.
mick1
Main scooter: Li Avanti 225
"new stator".....could the timing be set too far retarded after the change ?
watto66
thanks for the replies stator was timed ok what can i use as an alternative to the jetex ? trying to keep it standard looking are they just all poor quality . its been running lovely
