Brake drums
Hammerite
Main scooter: Sx150
I seem to have a problem with the brakes on my sx 150 . Is it possible for the drums to become elliptical ? I,ve had this braking sensation on the front for a year or so and now I,ve got it on the back. Its like the shoes biting unevenly if you know what I mean
Is it likely to be a shoe problem or a mis-shaped hub
Rich
bristolmod
yes- generally caused by the application of the brakes whilst the vehicle is stationary ( e.g. to hold the rear hub to facilitate the removal of the securing nut for example)
Scootering since 1968.
Hammerite
Main scooter: Sx150
Is that a 'yes' to the hub mis-shapen or shoes buggered ?
Rich
bristolmod
hubs mis-shapen
Chris
Daggs
It could be the things previously mentioned. But, I once had the problem in a front brake and it turned out to be no more than dust build-up.
onthelam
Main scooter: not yet
Do you brake hard or softly. If always softly sometimes the shoes get glazed over time. As much as you dare without falling off :o do a few really hard braking stops and see if that clears it up.
But as has been said it could be nothing more than dust. If you don't usually go fast , a few high speed runs may also not clean out the dust as such but clear it from where it is.
Burnside
Main scooter: Lambretta TV200
onthelam wrote:Do you brake hard or softly. If always softly sometimes the shoes get glazed over time. As much as you dare without falling off :o do a few really hard braking stops and see if that clears it up.
Recently had to change my rear pads as they had glazed. I only ever really use the rear just to put the break light on mainly using the front to actually stop, maybe I should use the rear a bit more often to actually stop
Hammerite
Main scooter: Sx150
Thanks for your replies fellas , will take a look when I get a chance
Rich
Hammerite
Main scooter: Sx150
One of the shoes was glazed over . Thanks fellas
    Users browsing this forum: Semrush [Bot] and 6 guests
