Crap low revs running
vRSG60
SIL GP200 Jetex 22mm SOI-100 carb with jets pilot 45, main 123, choke 50 NGK B78S Rayspeed Fresco exhaust
Starts fine & runs fine if over 1/4 or 1/8 throttle, below that runs like a sack of spanners. If it was a car I'd say is was "missing".
Screwing the airscrew in or out makes bugger all difference, unless I screw it all the way in or all the way out.
This was a problem last year but I had another toy to play with and so it's been sat for 6 months. Problem still here now I've come to use it.
mick1
Main scooter: Li Avanti 225
Not sure what plug you've got but if it's a B7 i'd change it too a B8.
If you've got the chance i'd change the carb' for a Dellorto (Jetex's can be very unreliable).
vRSG60
Thanks yes should read B8 and yes Jetex are shite. Other than that not sure what to do. I have a better quality air filter on order I'll give that a go.
dapper
Most suggest changing to original Dellorto jets. Available from Splat Shop I believe.
vRSG60
I put Dellorto jets in , I think! When I changed them.
Chris in Margate
Jetex when set up correctly are NOT crap !
Strip carb and clean pilot jet circuit. Fit 50 pilot.
Check that float is free to swivel.
If that don't fix it it may be electrical.
B7, B8, B9 won't make diddly squat difference to your posted symptoms.
vRSG60
Thanks Chris. I fitted a new CDI which helped last year when it was very difficult to start. I have a 48 pilot I could try that.
