UNI silent blocks
RBG
Gentlemen.
What's the quality like with the UNI made silent blocks?
Are UNI products generally considered good or not?
Thanks.
Genuine uni stuff is in my opinion good there hubs are well made and they do a AF type lightened flywheel that looks and feels good plus there a 120watt stator that looks as good as the bgm ones for about £45
the main thing to do is buy from a reputable dealer as like most things in life quality and construction can vary , its a good idea to check every component is securely fitted together
RBG
Thanks for the reply Shocky.
gaz_powell
just put a set in my sx - they look and feel as good as SIL/SR ones I ve used previously.
I have 2x uni hubs on bikes which I rate and as said their 120w stator looks well made (I would buy one when needed)
buy from af and you know they are genuine
gaz
Some of the Uni stuff I've fitted has been very good, other Uni stuff really shouldn't have made it past quality control... or even the design stage :(
I still use the stuff but it can be a bit hit and miss... then again, so can most manufacturer's stuff!
Adam
