SSC rear disc
Posted: Fri May 08, 2015 3:50 pm
by vicvega
has anyone got fitting instructions for this. Back end is pretty straight forward its the hydraulic cylinder and the arm its on, can't see how that fits to the frame. Cheers
Re: SSC rear disc
Posted: Fri May 08, 2015 6:51 pm
by gerryjunior
the bracket or round bar has to be welded to the frame , it sits like this underneath. sorry no bracket pic but ill take one if your not sure.
Re: SSC rear disc
Posted: Fri May 08, 2015 6:54 pm
by gerryjunior
heres the other side,
Re: SSC rear disc
Posted: Fri May 08, 2015 7:35 pm
by vicvega
Nice 1, thanks. It said on the site the bracket bolts on but welding makes sense.
Re: SSC rear disc
Posted: Sat May 09, 2015 9:36 am
by steve ss 2
gerryjunior wrote:heres the other side,
that looks neat but how easy is changing the rear wheel with one of these fitted?
Re: SSC rear disc
Posted: Sat May 09, 2015 1:26 pm
by gerryjunior
a right pain in the hole id imagine, haven't had to do it yet,
Re: SSC rear disc
Posted: Sun May 10, 2015 2:34 pm
by Dell Oughta
Are these pics any use to you?
I modified mine to use the standard brake pedal and also the bit 'arm' bracket thingy that your supposed to weld your frame struts to I welded a bracket to that so I could bolt it to frame struts
Mike
Re: SSC rear disc
Posted: Sun May 10, 2015 8:14 pm
by vicvega
Cheers that's a good idea and really useful pics. Thanks for that.
