socks
Greg Casey
Main scooter: lambretta j125
Bit of a Div question .. but im very new too scooters .. on my rear suspension i have a damper and besideit is the suspension spring but there should be something inside the spring top and bottom comming out of the shock plates too stop the sping falling out... can someone plz tell me what they are called so i can try order a set.. its a 1966 j125
lambro
Socks :lol:
http://www.scooterrestorations.com/lamb ... uspension/
Some parts mentioned on here, a quick phonecall to Scooter Resto's will get you the parts you require ;-)
Shaun.
lambro
I converted my last J rear suspension like this:
I made a spacer for the lower mount to take up the width difference between a Vespa smallie and the J, other than that a bolt on conversion.
Rear J dampers are quite pricey, and this Smallie shock was only a fiver 8-)
It looks close to the engine case, but when it was sat upon there was loads of clearance.
Much better than the fecked shock that was on there.
Shaun.
Greg Casey
socks ...lol... oh my god lmao... just seen it now.. thanks sean nice job ..
Greg Casey
nice info lambro thanks ;-)
