Dellorto sh1/20
Geocamper
Main scooter: Tv175 S2- Li 150 S2 Eibar
Is anyone using this carb on their series 2? Just would like to know what inlet manifold you are using?
scooterslag
The inlet spacing's will be the same on all the 125/150/175 barrels so one off a SX150/TV175 S3 should be fine for your series 2 barrel . Paul
The mack daddy on the left!
Lamaddict
Great little carbs that seem to be underestimated, best of luck with it.
Geocamper
Thanks guys. Need to. Source one now.
scooterslag
Sometimes people flog inlet manifolds on fleaby and don't list what it is size wise, the part number on my SX manifold is 19.41.1004, you may be able to snag yourself a bargain, hope this is some help. Paul ;)
Tony Hart
Main scooter: Lambretta S2
Geocamper wrote:Thanks guys. Need to. Source one now.
I've got a SH1/20 fitted to my S2 and if you have extended engine mounts it can be difficult to get the carb vertical without slotting the manifold mounting holes. I may have a spare manifold at home but am not back until the weekend. I will have a look and let you know.
