best brake shoes
db67
Hi , just wondered if anyone can recommend a decent set of gp brake shoes. after spending the best part of today filing,sanding ,adjusting, hub on , hub off , trying old shoes, partially worn shoes all I can get the brake to do is either be really spongy or the other way is the brake is constantly on !! the hub is a brand new sr sil one so I know that's ok i just want some recommendations before I fork out for another set !! many thanks for any info db67
What's your engine casing?
Some SIL ones are thought to be machined incorrectly where the pins are and can be hard to set up. That's why Jockey's brought out their kit.
mick1
Main scooter: Li Avanti 225
Rayspeed sort your shoes out for about £20. they take your hub off, put on a skimming tool and whip the excess off the shoes to level them up. My mate had it done and it was money well spent.
I 6sed an old hub with very corse emery super glued inside were the shoes would touch refited then span until the shoes just touched then as the shoe wears down use the cable adjuster a few turns , you might have to take the hub of to remove the dust and check theat both shoes have been filled away mine now locks up at almost any speed
indian casing the mekado (or a name similar to that are reported to be good there indian and cheap )
speedy
The Mikano shoes that AF sell seem to work well and be of good quality and are Japanese of origin.Cheers,Speedy.
bristolmod
re the dust- be very careful. Some shoes are still full of asbestos.
Scootering since 1968.
storkfoot
speedy wrote:The Mikano shoes that AF sell seem to work well and be of good quality and are Japanese of origin.Cheers,Speedy.
Are these different to Makino ones which are Indian, but pretty good imo?
Agent Buchwald
I fitted some Mikado ones but it was a bit of a song and dance.
Agent Buchwald wrote:I fitted some Mikado ones but it was a bit of a song and dance.
As much use as a chocolate breadstick....
onthelam
Main scooter: not yet
There is a reason mechanics are called mechanics, and fitters are called fitters. ;)
