Px 125 kits & setups?
H,POOL GADGE
Orite Lads, Asking for one of the lads, he's wanting to Kit/tune his px125 and use a standard carb 20mm or 24mm, who's using what kit and setup and hows it performing? cruising and top end speeds....thanks lads!!!! :D
ducksta
dr kit mazz crank 24mm t5 carb saxon exhaust sits 50/55 top 66ish very reliable so far
Parmakit with 60 mil crank. 24 mil carb. JL pipe. 4.8 gearing. About 75mph flat out. Cruises fine at 60/65. Does 180km to a tank.
gaz_powell
I`m just about to do a similar for someone
DR kit, keeping 20mm carb, sito plus exhaust
I`ll tidy the casings up, match the inlet, make sure all the gaskets are cut correct and open up air filter and rejet
might have to play with the gear but will wait and see once ran in.
he just wants a bit more acceleration and top end - he doesnt want a monster tune and he didnt want to spend a lot
Gaz
