Post tuning barrel clean up
Snails
Ok, I'm playing around with SR barrel (not like that!)
Cleaning up the ports etc
What's the best way ensuring I have all metal sandings out of there before reassembly?
Norrie Bodge
A rinse in fresh petrol & blow down with an airline always does it for me!!
Snails
I dont have an air line unfortunately - I already tried using a hair drier - not very effective. :D
I'll go with petrol rinse for starters though.
onthelam
Main scooter: not yet
Spray it with engine cleaner then rinse with water from a hose pipe or even in the sink. You might get some flash rust in the cylinder but you can ignore that. Or clean it with WD-40 on a rag.
SKP
Clean petrol & an old paint brush ................
SKP
smiffy1968
Main scooter: Nevermind Mk1 T5
Pumped up inner tube connected to an air gun.
onthelam wrote:Spray it with engine cleaner then rinse with water from a hose pipe or even in the sink.
I also use the kitchen sink method, with a bit of ingenuity you can also rig up 2 hoses to squirt down the transfers at the same tim which will give you at least some indication of how the transfers flow.
Good rinse in a bucket of paraffin
LI150
Main scooter: Series 2 LI150
Brake cleaner. Come as an aerosol it will clean all. I find its great for cleaning the crap of carbs also problem is its not cheap
daniel whiteley
Main scooter: 125 special
along long time ago (in a galaxy far far away as i was only a lad) i used to burn my rdlc out alot and when i had it rebored the guy who did it me used to tell me to wash it out in a bucket of hot soapy water !!! and then dry it out with a towel , i never had any issues doing it that way
