torque wrenches
Shuggie
any recommendations for a decent torque wrench to suit a lammy? cant seem to find any that will cover the full range of torque settings, any suggestions? cheers
barnsleybilly
Main scooter: Li200
You'll probably need two if you want to cover the full range, i.e. rear hub down to sidecasing nuts.
I use a Norbar torque wrench that's rated from 5 - 45 il ft which covers most jobs.
Tractorman
I doubt you will get one that will the full range from back plate to rear hub. Recommend two, a 3/8 drive for smaller engine stuff and a 1/2 drive for the rest.
Just that little bit quicker BB
HxPaul
I use a beam type torque wrench which can be used in both directions,good for torquing the flywheel nut.
I have two Halfods ones had @ 5/6 years been spot on , added them to my Xmas list ;)
hendy
HxPaul wrote:I use a beam type torque wrench which can be used in both directions,good for torquing the flywheel nut.
Beam type are best, but they don't look as cool. Wish I still had mine.
Tractorman
By beam do you mean the square for the socket knocks through the head of the torque wrench?
Tractorman
Does this work on l/h threads and will I need to sell my scooter to buy it?
eden
works both ways yes
