P200 Timing
Posted: Wed Apr 15, 2015 8:38 pm
by ArmandTanzarian
Hello all,
What is the recommended timing for a p200 with a lightly tuned standard barrel? The original spec is 23 degrees but that was presumably set in the good old days of full-fat, man's petrol rather than the crap we get now.
Re: P200 Timing
Posted: Thu Apr 16, 2015 6:40 am
by fastfrog
19° less risk of pinging/seizing.....
Re: P200 Timing
Posted: Thu Apr 16, 2015 4:57 pm
by gaz_powell
The 'A' mark corresponds to 23 degrees and the 'IT' mark corresponds to 18 degrees
I`ve ran on `IT`18 deg for years.
always relied on the casing and marks on geniune piaggio stators without fail
Not sure that can be said forthe glut of cheap ones available.
Re: P200 Timing
Posted: Thu Apr 16, 2015 7:31 pm
by Norrie Bodge
Agree with Gaz IT mark 18degrees
Run it also with a NGK B8 or a B9 for hard motorway use
Re: P200 Timing
Posted: Thu Apr 16, 2015 7:46 pm
by Daggs
Would that timing (18*) apply to a PX125 engine?
Re: P200 Timing
Posted: Thu Apr 16, 2015 9:03 pm
by gaz_powell
px125/150 were originally set at 18 (IT) - in this good old days - I would nt have a clue what they are now what with the restrictions they come with a stock.
Re: P200 Timing
Posted: Fri Apr 17, 2015 7:20 am
by ArmandTanzarian
I measured everything very carefully, strobed it all up and concluded that the IT mark was pretty much spot on 18 degrees. I thought I'd better check as it's an old ducati flywheel and a BGM stator.
Re: P200 Timing
Posted: Fri Apr 17, 2015 10:14 am
by goldeneye
always ran my standard P200E"s on 23*, or the A mark, bog standard, even the exhaust (only a T5 4th gear fitted) never had a problem . mildly tuned , the HB200 I had on, ran that at 18, or the IT mark. as gaz says, wouldn't know now, , as they have a different ignition fitted these days, made by Kokosan I think, with 12 coils on the stator, and a rev limiter built in and suchlike.
Re: P200 Timing
Posted: Tue Apr 21, 2015 12:49 am
by Lamaddict
Always run it 23 standard/standardish scoots but jetted correctly, same on my Lambretta's.
